hello friends.
so i have this box i need to overclock. specs are as follows:
* Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor
* ABIT AB9 Pro LGA 775 Intel P965 Express ATX Intel Motherboard
* Kingston 1GB 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory
* ZALMAN CNPS9500 AT 2 Ball CPU Cooling Fan/Heatsink
* OCZ PowerStream ATX, BTX, EPS12V 520W Power Supply
* BIOSTAR V6202EL63 GeForce 6200 LE 256MB TurboCache(64M VRAM on board) GDDR2 PCI Express x16 Low Profile Video Card
i've been able to push it as far as 340 external clock at 1.8vcore (default i think is 272/1.325 respectively) but it's unstable. when i bring it to 345 i get a bluescreen in Ntfs.sys. i assume part of it is ram-related but i'd like a second opinion and tips on how to get overclocked successfully (maybe 3GHz, maybe higher... i know it's possible).
i've checked neoseeker and tomshardware that had reviews and when i up the voltages of any of the other settings, the computer doesn't hit POST - it beeps upon startup with an error message on the mobo of C1 - check RAM.
now i have two questions - or well, three.
1. how do i get this overclocked successfully (and stably?)
2. IS IT A COOLING PROBLEM? if so, where could it be? i have checked everything but the cpu. therefore, how can i monitor the temperature of the cpu? i see mbm5 doesn't really exist anymore.
3. if you suggest a ram upgrade, what is ideal without breaking the bank?
THANK YOU
love,
tami :lips:
THANK YOU
love,
tami :lips:
