There are a few thing to look at first.
1)What motherboard do you have?
2)Do you know if the PCI divider is at 1/2 or 1/3? If it is at 1/2, change it to 1/3.
3)Check the above on you AGP divider, but check to see if it is at 1/1 or 2/3. If it is at 1/1, change it to 2/3.
4)Can you change the cpu (vcore) voltage? It will either be in your bios or a jumper on the motherboard. You may want to bring it up a bit. It's been a long time since I oc'd a 300a, so I can't tell you what the voltage should be.
5)A stock hs/f will work fine getting that cpu up to 450Mhz.
The reason you want to set your PCI divider to 1/3 when you have your fsb at 83 is because you need the PCI bus to be as close as possible to 33Mhz. 83* 1/2 is 41.5, which can really strain your PCI cards.
The AGP bus is specced to run at 66Mhz, so you want your divider to set it as close to 66 as possible.
