Need help ordering replacement PSU for an E-machine
bucwylde23
Do the e-machines use all standard PSU connectors>?
I need to replace a Bestec ATX-250-12E from a E-machine T2542.
I don't need a fancy one, just need it to work.
Can anyone give any advice? thanks..
T2542 is a standard micro ATX case with a standard ATX PSU.
But don't get that Rosewill. One, it's a micro ATX. Two, it's of questionable quality. I know your Bestec died, but that Bestec is five times the PSU that Rosewill is. Unless of course you want to replace the PSU again in a couple years.
