1. I am planning on using the computer for League of Legends and the streaming of it, as well as some photoshop and recording of League.
2. I have a budget of $730-775 for everything but the case and a $100 budget on the case alone.
3. I will be buying the parts from the USA.
4. N/A
5. Brand preferences: Intel other than that I am not picky
6. I have no current parts except for mouse, keyboard, and monitors(2).
7. I do not plan to overclock.
8. I will be using a 32" tv as my main monitor and a 21" auxiliary screen.
9. I hope to build it ASAP.
10. No software is needed.
This is the build I have so far which is slightly over budget:
http://pcpartpicker.com/p/pfjbVn
I plan on getting an on-board capture card a little down the line as well and I have this one in mind.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815100100
And as far as the case that is on a separate budget of about 100 dollars so if you have any suggestions for streaming friendly cases I am all ears. I currently have this one lined up for 90$:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147053
Thanks in advance for any help because I am very new at this whole computer building thing so any advice is welcome.
4. N/A
