Belikemike71684
Banned
I have decided to upgrade my slow P4 1.8ghz Dell 512 ram by getting:
Lian Li case
DFI Lanparty UT 250gb motherboard
AMD 64 3000 2.01ghz processor
Corsair ValueSelect 512 MB 184-Pin DDR-DIMM (two of them to make 1 gb)
when i installed everything into the case and tried to format the drive and reinstall windows, either one or a few of the following happened, constantly. (i have formatted and reinstalled windows 4-5 times within 12 hours):
1. The computer would restart by itself when it got to the windows xp load screen
2. the monitor would go on standby(off) and the computer would be either doing nothing or be trying to run my dvd drive.
3. While installing windows, at the end when it finishes up, it would go to the blue screen and say
"Machine_Check_Exception"
"***Stop: 0x0000009c (0x00000004, 0x00000000, 0xB2000000, 0x00070f0f)
"Beginning dump of physical memory"
4. when i finally installed windows xp and shut down and restart or just restart, the computer would do the standby thing (#2) or it would go to the screen telling me to select to go either on safe mode or normal mode or last known settings.
(right now it is connected to a dvdrom drive, radeon 9600 video card, soundblaster live sound card, floppy drive, seagate 80gb hardrive, and a used unknown 350 watt power supply.
PLEASE HELP!!! IM GOING CRAZY AND FEEL LIKE MELTING THIS ALL DOWN TO NOTHING!!!
Lian Li case
