Need help on stupid swamp level on JKII
StageLeft
70,150
Funny thing: When this level started the first second the screen loaded I thought this was going to be a really retarded level and I was right. Not only do i have to lower my res from a normally fast 1024X768 to 640x480 to keep the frame rate adequate but the level just sucks.
So anyway how TF do i get anywhere? I killed the morons and go to their stupid crash site but now what? I can't jump anywhere worthwhile. I've spent about 55 hours trying to jump in the back of the ship but that is no use.
Thanks in advance
Hammer
13,217
You're almost to the end Skoorb. At the first crash site, you need to dive under water to head over to the next section.
StageLeft
70,150
<< You're almost to the end Skoorb. At the first crash site, you need to dive under water to head over to the next section. >>
I checked :( Any specific spot I should be looking for? I didn't check all that thoroughly. Honestly I spent only about 35 min on the level and realized I had no idea what to do anymore.
Rent
7,127
Should be on the left... lemme see if I can go back thru and get a screenshot
Skel
6,226
686
You should see a spot with water comming out of one of the rocks. That's where you go under.
Skel
Hammer
13,217
I'm not at home so I can't get you a screenshot. Look underwater under one of the mountains. You should see the base of a tree.
Rent
7,127
Skel has it - I don't have debug on right at the moment but if you look at the rocks there will be some water coming out right over it.
StageLeft
70,150
OK I found it :) It was off to the side hidden, of course. I just took on a few of the black-armor saber guys and got a bunch of powerups so I'm continuing on later. How many levels are left?
Hammer
13,217
You're on the last major level, and I think there are 2 mini level from where you are.
NikPreviousAcct
52,763
Yeah, the whole Jedi Temple thing isn't a real level
It's perhaps one of the most fun levels in the entire game.
nik
