Need help on psu
Twister2004
604
hello all i can get these power supply's dirt cheap for 10$ a piece they are for a hp xw8400 workstation and are 800 watt and they are 24 pin
have pci-e connector and sata connectors will this work for a am3 mb and a intel mb socket 775
please some one let me know if this will work for any of these motherboards thanks
sorry this is just a link to the picture of the psu am not buying from ebay the guy i can get them from is local to me just want to find out if it will work with these types of motherboards
here is a link to the hp psu
http://cgi.ebay.com/405351-003-HP-8..._EN_Networking_Components&hash=item255dd084a4
405351-003 HP PSU POWER SUPPLY 8400/9400 800W
bruceb
8,874
111
First, they are $100 each, not $10
Second, shipping is $45 per unit
Third, seller is in Norway, so unless you
are in Europe or near there it may not be worth it.
TemjinGold
3,050
65
Wow... can you guys not read? He's not getting it from the ebay guy. That's just a picture to show you which one he's talking about.
dma0991
2,723
From the looks of that picture I determine that PSU to be a Delta OEM PSU. It will work well considering that it is an OEM unit but don't expect 80+ Gold certification with this PSU. As with all OEM PSU the 24 pin cable is a little bit short to cut cost but you can buy a 24 pin cable extension if it does not reach your 24 pin connector.
NZXT do sell the 24 pin extension cable but I am sure you could find cheaper alternatives than NZXT. If it was used for quite a while send it to your local electrician or disassemble it yourself to clean up the dust in the PSU.
Twister2004
604
thanks to everyone that replied i am greatfull will give one a try for 10$ look like the only thing it might not have is a 8 pin cpu connector only a 4 pin
dma0991
2,723
The 4 pin CPU connector would be enough even though on the motherboard has a 8 pin CPU connector. Just plug in the 4 pin into the proper side and sometimes a cover is given to cover the unused 4 pins in case there is only a 4 pin instead of a 8 pin.
