Need help on overclocking Gateway Radeon VE 64mb DDR
Ryan
Yes, you read it right, I have a ATI Radeon VE w/ 64mb DDR ram from Gateway. It is clocked at 168mhz, how much higher do you think it'll go?
<< I have gone up to 190 without noticing anything....... 🙂 >>
Im not an ATI user.. but loop something like 3dmark. 1 hour then raise it 5 MHz. repeat till it crashes before an hour is up. Then lower it 1 MHz at a time and look for the sweet spot.
