- Jan 26, 2005
- 84
- 0
- 0
Her is my setup on my rig i put together this weekend.
MSiI NEO 2 platinum
3500 WINCHESTER
2xOCZ Voltage extreme max 3.5 volts.
BFG 6800 GT.
OCZ Modsteme 430 watt power supply.
I am haveing trouble getting prime to run. At my current clock i got all the way through 3dmark05 no problems at all. But when ever i run prime i get this after about a minute
"FATAL ERROR: Rounding was 0.5 expected less than 0.4
Hardware failure detected, consult stress.txt file."
MY current bios settings are as follows.
HTT: 235
HT: 4
MULTIPLIER: 11
CPU: volts according to cpuz are 1.52-1.6
Memory Divider: 5/6 2 3 3 7 at 2.85 volts memtest stable My memory only shows that it is working in single channel mode is that normal or should i try to get it to dual channel. HOw do i got it to dual channel if need be.
Could it be the fact that my bfg is overclocked? I left it at 66 in the bios like everyone said to do but i have it overclocked. I am confused as this seems like i fairly conservative clock from what i have seen.
MSiI NEO 2 platinum
3500 WINCHESTER
BFG 6800 GT.
HTT: 235
HT: 4
MULTIPLIER: 11
