Im looking for a new PSU my old one 350watts just aint cutting it anymore but im not sure what to get. The menu has different types listed, and im not sure which one it is. I have a P4, in a mid atx case could anyone help me out on which ones to get? PLZ HELP
Edit: here was i am running
P4 3.0ghz
asus mobo 1GB ddr 3200
SB Audigy 2IDE
120 GB HD IDE
120 GB HD sata
DVD RW
DVD Rom
2x80mm chasis fans
1x120mm fan
I just burnt out the DVD rom cause the power supply couldnt handle it when the computer started up. I took it apart and the bearings the part that spins the cd , I can hear them when i shake the dvd drive
BTW im kinda on a budget
P4 3.0ghz
SB Audigy 2IDE
120 GB HD IDE
120 GB HD sata
DVD RW
DVD Rom
2x80mm chasis fans
1x120mm fan
