Hi everyone,
I'm in the process of building a new computer designed mainly for work but still offering a competitive edge in gaming and multimedia. My budget is around $2000 (Canadian) taxes in. I'm just a casual gamer and have no experience overclocking and don't intend to anytime soon.
Here are the specs so far:
CPU = Intel Core 2 Duo E6750 Conroe 2.66GHz LGA 775
-How is this processor in terms of OC'ing ability? It happens to be cheaper than a E6600 right now but is E6600 a better processor?
Motherboard = ?????
RAM = ?????
Case = Cooler Master Centurion 5 Black Aluminum Mid-Tower Case
PSU = Corsair HX 520 Watt Power Supply
Video Card = E-VGA GeForce 8800GTS 320MB PCI-E Superclocked
Monitor = Dell 22" Widescreen
OS = Windows Vista 32-Bit
Including all the other non-core components, my total comes to: $1600 tax in.
As you can see, I really need a recommendation for the motherboard and RAM. I was considering the following motherboards: Asus P5N-E, the Asus P5N32-E SLI Plus, the Gigabyte GA-P965-DS3 and the Gigabyte GA-35P-DS3R? Another motherboard recommendation is also np. As for the RAM, I'm not really sure what I should go for either! Can anyone suggest a good combo of Mobo + RAM?
Any suggestions for improvements are definitely welcome and appreciated
Motherboard = ?????
RAM = ?????
