Hi All - brand spanking new to this forum, so excuse me if I make any forum faux pas. I am attempting to take on a new project, but wanted to share my approach with folks who know better than I do to see if they can offer any better solutions/improvements to my existing proposal.
So here's some background on my project:
- I have a big house (four levels - including a basement level) that has about 25 rooms distributed between all floors.
- Students occupy these rooms and are heavy internet users. (streaming, downloading, etc)
- I have about six residential grade internet connections throughout the house. They are all those crappy modem/router combo gateways the ISP provides. They are situated throughout the house, on every floor, to provide a wireless connection in all areas of the house. I'm spending about $300-400/month to my ISP.
- Side note: While I am tech savvy, I have limited experience with networking. For example, I know how to replace DDWRT firmware on a linksys router, but do not know anything about how to run QOS on a commercial switch.
Problem:
Given that I do not have QOS setup on any of these connections, any one of these connections will come to a crawl once one person decides to torrent/download/stream. Not to mention, sometimes there are too many devices that login to one of the gateways - crashing the hardware. I have many complaints about the internet going down / internet being too slow.
Solution:
Whittle down the connections to one (ie disconnect most of them). Ensure that the one remaining internet connection is fast - at least 50MBPS.
Purchase a commercial grade 24 port switch that has QOS
Purchase eight wireless access points
Purchase a lot of cat5 cables
With the sole internet connection, connect the modem to the commercial grade switch. Run (8) cat 5 cables from the switch to each level of the house so that I have (2) cat 5 cables at each end of the house on each level. Connect the (8) access points to the other ends of the cat 5, providing wireless signals throughout the entire house.
Program the 24 port switch to limit the inbound rate of each port. Distributing the 50MBPS equally into each of the ports.
QUESTIONS:
1. Overall, is this a sound plan? If not, please provide comments on how to improve the plan.
2. Can you recommend a suitable commercial switch that will fulfill what I need? (I am willing to spend several thousands of dollars on this project if it is required.)
3. Can you recommend suitable access points that will fulfill what I need?
4. I understand that I will need to configure the network switch to limit the inbound rate on each port. I understand this may require a "console cable" and these settings are inputted via a command prompt. I am unfamiliar with this process. Can someone point me to resources that will teach me how to do this?
Please feel free to also point out anything I've missed. Thank you!
Problem:
Solution:
QUESTIONS:
 Facebook
Facebook Twitter
Twitter
