Need more details. If they're currently stored in a pst, select the mails/folders you want to move and drag and drop.
If you're going the opposite direction (mailbox to pst), you may be able to try the above method. Depending upon location of source and destination you may have to use the Import/Export wizard. It's pretty simple.
1. Import/Export Wizard
2. Auto-Deliver to PST, which will create all default mailbox folders in PST
3. Create a new PST (File>New>Personal Folders), select what you want, and copy/move it to PST
