i have a msi k8t800 ms-6702 mobo and a lian li pc-07 case! the first thing i noticed when i finally got d mobo mounted on the case was that it wasn't aligned with the openings on the back! i had a really hard time sticking my vid card (9800 xt) on the mobo. I had to literally force it down to lock on to the mobo. the problem was that it was a bit too much on the left and therefore scrapes with the metal on the back of the case. when i tried sticking a fire wire card ( dv-1000le) to a pci slot, it encountered d same problem. I had to forcibly push it down and i even had to bend the metal of the card itself only to find out that i couldn't use the fiwi ports from the outside because there was this piece of metal from the case that was blocking the entrance. is this a problem of my mobo or my case?
Another thing, i have one ieee 6 pin port on the front of my pc-07 case. it was connected to a wire with 9 holes.
http://img39.exs.cx/img39/5343/fiwi.jpg
i tried looking for anywhere to stick it in the mobo only to find out there wasn't anything nor any mention in d manual. is there any way i can make my ieee port on the front work?
