Need help on MoBo --AMD Suggestions ONLY--
RazeOrc
269
To keep this as orderly as possible please read the title before posting.
I've fallen off of the wagon as far as MoBos are concerned as I haven't had any personal need in purchasing in some time and the ones I did were for Intel. I am putting together a budget "bang for my buck" pc for my sister. I already have all the parts except the mobo/ram.
Ideally I'm looking for an AMD MoBo that supports FSB and Multiplier OCing as the 1700+ b comes unlocked or some nonsense like that, and I hear you can get quite a bit out of them from stock speeds. It should also support DDR200/DDR266, don't really care about newer stuff since it's that much more expensive and upgrading isn't a huge concern here as my sis can use this thing for 3-4 years. Oh It should also be REALLY REALLY inexpensive, as CHEAP as possible. I haven't found much under $78 shipped that meet my critera but the cheaper the better, thanks to everyone who throws in their dirt.
magomago
10,973
14
nforce Asus? 71.99 @ newegg
comes with lan/audio/and a integrated geforce2mx
I beleive its the Asus A7N...something
Its usually on the main page
human2k
3,563
look at my sig....ive got a tbred B 1700XP from newegg.com on friday and its running speedy at 1.81GHZ with the multiplyer at 12.5 x 145MHZ FSB on the MSI kT3 ULTRA. Newegg has this board for $80, too badd it doesnt have pci/agp lock. You should SERIOUSLY consider the Epox 8RDA+ from tcwo.com for $108, not only does it have pci/agp lock and soundstorm, but you get free s/h;).
RazeOrc
269
Wow, thanks for the speedy replys guys, I think i'm gonna opt for the nforce Asus A7N266-VM AA 71.99 @ newegg, GF2 still runs most current games and will do Autocad2002, good help guys, thanks!
Bovinicus
3,145
The onboard video on the nForce is no good. It is extremely slow. The GF2 MX is nowhere near the performance of the GF2. Plus, I thought you had everything but the motherboard already anyway... The nForce board is still good, I would just go with the one without onboard video and save a few bucks if you don't really need it.
