BuckarooBanzai
OK, here is my situation.
My floppy is fubar'd to hell and back. I don't want to buy a new one for I will not be using it
in future. What I need is a link to someplace that has a bootable win98 or XP floppy image
or anything that I can burn to a cd that will put me into a DOS screen so that I can use a
program, MBRWorks, that I need to use to fix a problem with my HD reporting only 33 gigs
instead of 40 that it is.I used to have my HD partitioned into 2 20 gigs. But I deleted them
and made a new partition but it only reports as a 33 gig. I have used fdisk and Partition
Magic and they can't fix it. I used MBRWorks before with a 20 gig I had once that did same
thing with bad reporting so I know that it will work with this one. Any ideas? If you know of
a way to fix my HD problem without the described solution that I provided please come forth.
