Here's a side view of the case (not my pic):
http://arstechnica.com/reviews/1q99/q500side.jpg
reviews: http://arstechnica.com/reviews/1q99/q500a-2.html
First off, my case came with the power supply fan pointed at the top, so it is sucking air in from the top side. This seems like an easy question but shouldn't I flip that power supply around so it sucking the air directly across from the motherboard? I don't know why I didn't do that sooner...
The big problem is that front intake at the bottom located inside that plastic housing does not bring in enough air. I put my hand in front and barely feel anything. The reason being, the fan is right up against the metal with only a bunch of small hole to draw air in from and also because the plastic front casing does not provide much openings for air either. The author of the review mentioned this is a perfect case to use a dremel tool? What exactly is it, how much does it cost, and how would I use it here? I know the solution to my problem involves cutting the metal and maybe altering the front of the case, so what other options do I have? Is the dremel tool the only tool that can do this? Thanks.
