Need help on getting better picture on split cable line
Namuna
2,435
The Cable installer ran the line to my TV in the living room, then used a splitter and ran that to my office/computer room...I took the splitter off and used my VCR as the splitter instead. All well and good, but the signal from the splitter/VCR to my office is degraded.
What can I get that will give me better quality?
Thanks for any help.
N8Magic
11,624
If its normal analog cable, you can grab a line amplifier from Radio Shack for ~$20.00.
Just make sure you put it BEFORE the splitter, otherwise you'll be amplifying the degraded signal.
Namuna
2,435
Thanks N8Magic.
Here's another question, since I'm using the VCR as the splitter...Whenever I turn the VCR on, it TOTALLY kills the signal going to the office.
Any idea on what I can do?
N8Magic
11,624
When you go to buy your amplifier, grab a splitter. They are SUPER cheap, and it is specifically made to do switching, so the degradation won't be nearly as bad.
