I am going to network 32 machines. I need to know the cheapest switch that I can buy that will allow me to disable and enable certain ports on the switch. I assume I need a managed switch but can someone recommend a cheap one. I do mean cheap, it does not have to have all the nuts and bolts, I just need to be able to disable certain ports.
thanks for the help
thanks for the help
