I bought a new system consisting of:
Asus P5K-SE
E6550
2GB Kingston 667
1950 Pro 256mb
Audigy 2 ZS (re using this)
Seagate 250Gb SATA
The p5K has onboard audio , so i disabled it as i wanted to use my audigy. However , after installing Windows XP , i found that certain audio devices were already installed.
They are:
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
Video Codecs
I can't uninstall them or disable them as there is no option to do so. In the Sounds and Devices panel , it says "No audio device is installed" even when these things are already in Device manager.
Can't select anything else , can't install anything else either.
Best part is , the Audigy 2 drivers will not detect my Audigy sound card and i cant install them.
I tried installing the onboard audio but all i get it "Not enough resources" or something close to it and till now , still no sound.
Help? I formatted 6-7 times already , first with Audigy installed , second i took it out , third i tried enabling onboard audio before installing XP etc etc etc
I'm going nuts...
Asus P5K-SE
E6550
2GB Kingston 667
1950 Pro 256mb
Seagate 250Gb SATA
They are:
Audio Codecs
Video Codecs
I'm going nuts...
