Need help on configuring a multimedia network
Platyply
105
Moving into a new place and I haven't really been keeping up with the latest networking and wireless technology since I bought the Belkin N1 last year. I want to build a network (I have a PC, MacBook, and Airport Extreme) and need some advice based on the following:
1) I want to access my iTunes library, Netflix, and movies from my TV, PC, and MacBook
2) When accessing my music from the TV I'd like some visual interface so I can pick things out from across the room
3) At some point I will add a Xbox 360, PS3, and Slingbox to the network
4) SugarSync currently backs up my data, any other suggestions-- should I get a back-up drive my PC and another (Time Capsule) for the Mac?
I've heard of Roku, ZeeVee ZvBox, HP Smart Media Connect, Apple TV, and MythTV; but I'm not sure what will work given that I have a PC/Mac network.
I appreciate the advice, thanks!
mcmilljb
2,144
Xbox 360 live will offer some netflix movie downloads soon, so you might want to consider getting one of the discounted xbox 360's unless you download a lot of netflix movies that will fill up the 20gb hd. AppleTV will hold your itunes, although it's a bit pricey, and will give you a visual interface to listen to your itunes.
If you want a more all-in-one solution, you could consider building a low power, htpc/server box to house all your files plus it can be connected to your tv. People in AV&HT can probably help you get going down the road better than this forum.
