Need help on choosing Dual display view video card
KaliBoy819
45
Hi, i dont know which one is good between
Ati Radeon VE
Matrox G450
or anyother dual display video card out there that you guys would recommend???
It will be running on a Win2000 Server
MSI K7T Pro-2A (Thanks to you people help me pick this out :) I love it )
AMD Tbird 800
with 256MB pc133
Thanks in advance!!!
arod324
1,182
If you check out the article on anandtech, it shows that the Matrox has better options if you are a CAD/workstation person, because it has better dual monitor capabilities. However, the VE has better 3D performance. So I think if you are a fairly avid gamer, the VE should be your choice.
