Need Help on Bytecc ME720 Enclosure
hsfnewbie
If I install the outside rails on the case, it seems like I will never be able to open the case again if I wanted to swap out hard drives.
Do you guys know a work around on this other than not install the rails? The rails i'm referring to are the plastic flexible things where they supposedly lock the bottom and top part of the case. I only have one installed right now.. and i'm looking around for any kinda hole to pop it open if I was to install the other one.
Any help would be much appreciated.
Thanks.
