i don't know how much this help, but back in the days when i was using those pentium machines, the fan is physically "screwed" to the hs. that means just put the fan on the hs and "screw" it (hmm....) I don't know if that helps, but since there is a hs on the MX chip already, you might just use 4 screws and fix the fan on the hs.
