Need help on a PSU
tvfreakazoid
😱Here's a link about a PSU I plan on getting. I'm kinda stumped of what the description is saying. Here's what it saids:
Important Note: The TruePower 2.0 Fan Only connectors are designed to power standard fans only. Attaching thermally-controlled fans to these connectors will likely result in unpredictable and undesired behavior. Thermally-controlled fans should only be connected to the standard 4-pin Peripheral Power Connectors. Please do not connect more than three fans to the Fan Only connectors.
And here's the link to the site: http://www.compusa.com/products/product_info.asp?product_code=332499&pfp=BROWSE
Is this a good PSU for a OPTY 170? Good psu or not good? Does this psu have sata 2 connectors or just sata? I have 5 case fans that came with my Case.
