- Feb 5, 2005
- 984
- 1
- 0
Right now it's at 2.4Ghz, loosened the timings to 3-3-3-7. FSB 266, ram is at 180Mhz stock voltage stock cooler.
Any higher than that and the system is unstable, or wont get past the windows startup screen.
I am aiming for 2.6Ghz I believe the limitation may be one of two things:
I am using 4 DIMMS, however since the ram is running below 200Mhz I don't think this is the problem.
My room gets fairly warm I suspect the stock cooler may be insufficient for 2.6ghz-2.7ghz.
Suggestions?
Suggestions?
