need help OC....
I need help on how to OC an ABIT VP6 with Dual P3 933.....
I attempted to go to a 1. 0 GHz but the settings won't hold....
what else do i need to do??
what do you mean the settings wouldn't hold? the system doesn't post? you might want to try upping the voltage a bit if that's the case.
Thanks for responding....
What I meant was that the changes I made to the BIOS don't stick after restarting the box. The speeds are still @ 933. I want to know the proper way of upping the voltage safely.....
much appreciate...
