Need Help OC CeleronII
CCrunnernb
1,002
I got an Abit BM6 and a CeleronII 533 currently at 800 at 1.7volts, did the HardOCP trick so default is now 1.65 so i have 1.85 in bios instead of the 1.7. How far could i take this, with the Gorb and a little thin piece of metal that lowered my temp about 10 degreesF.
they call mr big
417
depends pn what temps are you getting?? might be able to get up to 900, pretty lucky if you do. got good case cooling???
Bartman39
Elite Member | For Sale/Trade
Jul 4, 2000
8,867
51
You might take a look at www.overclockers.com and compare your cpu`s markings to some in their database to get an idea but Mr. Big has a point about cooling those little Celerons get hot...
BTW I have a 533a @950 1.80 in the wife`s puter and will do 1000mhz 1.85 but gets to hot for my comfort...
Killer Ape
1,352
My 533A hits 825 at 1.65v using a MSI 6905 Dual (PPGA only) slotket, Gorb, on a BX6r2. She'll do 897 (112MHz FSB) at 1.9v, but sometimes flakes out in UT, otherwise it's stable. I run it at 825 simply because it's completely stable and there's not that much of a performance increase to run it at 897. Under load at 825 it stays around 40C. I've seen people hit 933-940 with aircooled 533As, but it's pretty rare to keep them stable there.
