Need help o/cing MY MX.
Balex99
356
SORRY ABOUT THE CAPS BUT MY KEYBOARD IS FOULED UP. UPDATED MY MACINE AND VID DRIVERS AND NOW THE CLOCK SLIDERS(HARDWARE FOLDER) ARE MISSING FROM THE NVIDIA UTILITY. I CANT O/C MY CARD. HOW DO I GET IT BACK??? PLEASE HELP.
nate hancock
104
Balex,
I have an Asus 7100 MX and the O/C functions were in a separate Tweak Utility that you had to install separately. Maybe you have a similar setup with your card but forgot to install it when you updated? I am using the Asus drivers and not installing the reference nVidea ones.
Have you successfully oc'd your card before? I tried setting my sliders up on my Asus & rebooting but my performance in the UT demo actually lost a few FPS. Any suggestions, anyone?
nate
Packet
557
Goto tweakfiles and download the Geforce Tweak util, it has an OC slider, plus an option to enable Coolbits.reg
"I tried setting my sliders up on my Asus & rebooting but my performance in the UT demo actually lost a few FPS. Any suggestions, anyone?"
You shouldn't have to reboot to overclock, but I have herd that if a geforce gets to hot from OCing it can actually slow down.
I would go with small % at first, like 10% - 20% - 30%, etc and see what works for you.
