Need help. New PC Won't POST
tdv50144
I recently have started to put a build together. I put all the pieces in and now the computer will boot for 1-2 seconds and then reset. It will do this over and over until i unplug the power. The q code is 13 which is cpu post initialization. There is also a red led on the Mobo that lights up during that second or two and it says dramled. I noticed my bios may not be up to date so i updated it through the cool new flash bios feature and now i have code 13 and 35 before the computer shuts off. The Ram i am using has led's on it and they light up during that 1-2 second period so i don't think it is the ram. If any knowledge could be shared i would be appreciate it. I don't want to RMA the mobo and the CPU when it could have been fixed.
Things that i have tried:
Updated bios
Unplugged all components except power cpu and ram
reset cmos
reseated cpu
Specs
nzxt phantom 820 case
asus strix x99 gaming Mobo
nxzt kraken x61 watercooler
i7-5820k
corsair hx850i psu
corsairDominator Platinum 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000)
samsung 950 pro m.2 512 gb
