Need help, my system tray icons are gone
Joe750
Somehow all of my system tray icons (some of which I need to access the programs) are gone. It's just the clock now. The software is running, but my Kazaa, Norton, PowerStrip, and Java icons are all gone. There is no settings I can find to turn them back on, and I really need to use those programs! Powerstrip is only accessable through the icon, and now I am out of luck. Anybody? PS, YES I have right-clicked, gone to properties, and they are not hidden. Thanks in advance. -Joe
Have you restarted your machine after explorer crashed on you? Else, just kill the prog in TaskManager, and run it again.
This is an ongoing thing, like I toggled them off and now they won't come back. It isn't some programs, it is all system tray icons, leading me to believe it's a setting I can't find.
