ahdaniels76
So my goal is to get Comcast internet via cable modem and use its bandwidth to support a typical home network (wired and wi-fi) in a 3-story house with a detached garage/apartment (say 30ft from edge of house to edge of garage).
The house supposedly has some CAT5 wiring pre-installed, but it doesn't go to all rooms. My plan right now is to wire the cable modem to the CAT5 wiring, and then get a decent router and put it in a central room via a wired jack. Then possibly use a signal enhancer or something (if needed) to get a strong signal in the detached apartment (which doesn't have the CAT5 wiring).
Devices: 3 PCs, maybe an ipad, 2 smart-phones, a PS3, a Roku for streaming, and possibly at a later date a DirecTV whole home network (which I would start by using on the Coax wiring... which goes to the apartment, but supposedly has weaker signal due to the length of Coax).
I'm thinking a simple new wireless n (latest n?) router would work, I guess one that uses DD-WRT(?) for a stronger signal, although I've never used DD-WRT before. And then maybe either an electrical outlet - to - outlet signal enhancer (I read about this here, but it seems they work better unencrypted...) or some other device to ensure the apartment gets enough signal strength. I'm not sure if I need "switches" or anything beyond the router if most everything is wi-fi or connected via the built in CAT5 jacks.
So I'm looking for tips on good hardware specifics (had trouble finding anything quickly via searches), a good approach to ensuring adequate coverage, and some tips on the best way to extend the coverage to my garage apartment. I'd want my network secure, though, as I will be living in a fairly densely populated area. My phone picked up 9 other networks as I walked through the house...
Budget is relatively high to get the job done - although I'd prefer to stay away from super high end stuff ($250+ routers) if possible since my needs are not that extreme.
All help is appreciated,
Thanks,
Thanks,
