- Mar 26, 2003
- 141
- 0
- 0
I just started putting together my first water cooling rig and have hit my first problem. The TT XASER III has a mounting system that is one of those where you mount the two guide rails on both sides of the CD-ROM and then just slide it in. However, the bay-res I have doesn't have the holes in the same place. Has anybody run into this problem before and found away to fix it without it looking like it was just put toghether with tape and luck? Thanks in advance folks...
