Need help modding wireless usb card.
I do not know if it is worthwhile money wise to do so, but here you go.
This picture depicts the idea it shows a D-Link USB card that the Plastic original Antenna broke. A new jack was installed, the wire inside was cut short and was connected to new jack. It is ready to take any external Antenna with a matching plug.
http://www.ezlan.net/example/antenna_mode.jpg
