Need help making Solaris 8 CD images....
Harrisment
207
Ok on the Solaris site, it says you will need to rename the file after unzipping so that it is recognized by your cd burning software. It says for people using Easy CD Creator to give the file a *.iso extension. I did this and the icon still remains unrecognized. Do I need to manually associate this extension with Easy CD Creator, or do I need to use a different extension?
Basse
525
Just rename it to .iso and choose to burn from image in EZCD, opening the ISO file.
/B
