pm'd talonts already but in case he doesnt reply...
...i am not an electrician and as such am greatly handicapped with the project i am about to do. i have just modded my case... enlight 7237 (pic will be coming soon) and have just made a fan bus. i read somewhere on instructions on how to create a dual volt switch using the +12v and +5v from the molex connector. i went out to the electronic store and bought myself 5 toggle switches at 60 Php (about $1 and 2 cents). they describe it as on - off - on. it has six connectors at the back, two side by side in three rows. written on one side of the TS is 3A 250VAC and on the other side 6A 125VAC. did i just get the wrong kind or will these things work just the same.
also, i heard you suggesting on a 3pole dual color led. did i get it correctly? this would greatly help my design since 5 switches will be a bit crowded, i think.
last but not least... will 5v be enough to power my 2 120mm fans? read about "start up voltage" and dont have a clue about it. i also read somewhere that i can join the 12v and the 5v to get an output of 7v instead. i thnk 7v will be better.
TIA!
Ken
TIA!
Ken
