Question Need help lost a SMD while cleaning pc is running and no video output
Zai varun
Hey guys!
I need help with my graphic card which is not giving video output since i broke a Smd from the board (GIGABITE GTX 1650)
CAN any one suggest what to do rather than going to the service center.anything i can do with soldiering and what resistor should i use the R256 or R257 i got a small tiny metal thing cant say a resistor but after ripping that i got no display and i lodt that small thing gpu image 20211014_202530.jpgand refrence to original is below 12.jpg
Ajay
16,094
8,114
Both. Looks like R526 is on top and R527 on the bottom (mounted horizontally). I personally don't have enough soldering experience to try something that small, so a liquid solder might be a good solution.
Reactions: Zai varun
Zai varun
I appreciate the help but i dont have any of those resistors on mee cause i dont know the values of emm
MrTeal
3,919
2,708
Yeah, R526 and R527 is the designation of the resistor, it doesn't tell you anything about what value of resistor you need to replace it with.
It's hard to tell without a better picture, but it looks one of those pairs of differential traces goes to one resistor. If R523/R524/R525 have the same kinds of pairs of traces running to them, it's likely they're the same value as 526/527. You could remove and measure R525, and then use that value for the two missing ones.
Ajay
16,094
8,114
Dang you have a good eye!
Sorry, my bad. Up vote @MrTeal.
Zai varun
Is there a chance that i ill totally fry my gpu trying that or is it safe
