Hi all,
The moment has finally arrived. I'm looking for an engagement ring and need some help. I started to shop for the ring this afternoon. Had no idea the darn ring can be that expensive. Here is what I saw at the local mall (Short Hills Mall in NJ) Tiffany & Co and Cartier store:
Tiffany has a .82 carat, F grade, VVS1 on a Platinum ring for over $10,820.00
Cartier has a .73 carat, E grade, VS1 on a Platinum ring for $8,700.00
Ok, I like to keep the budget under $8,500.00 if I can.
The size of the rock should be between .73 ~ 1.00 carat, grade D,E, or F, with VVS1 or VS1, not sure how to measure the cut.
Questions:
1. For my budget, what's the best combination of the 4 Cs I should be looking?
2. Do women perfer size over quality?
3. Does it matter where or what store you bought the diamond from? Does the certificate really means anything?
4. Is there a big difference in Color between D and F grade?
5. Any jewelry store I should aviod going in Tristate area? (rip offs)
Questions:
