jazzisjazz
Howdy all,
I need to locate a cheaper source for this part.
http://tv-allowance.com/netprotector_tamper_clips.html
It allows you to remove the little plastic tab on a rj45 connector,
put the part in place and then when the connector+part goes into the female jack it locks in place to provide a reasonable amount of tamper protection.
It is plastic and blue in color.
I would love to know who makes them hopefully I can buy in bulk rather than $2.00/ea
Thanks for any help.
