Hi there,
I read an article in maximumpc (Link) titled "How to keep your electronics cool in a closed cabinet.
I would like to install this fan into the back of my cabinet. The piece of furniture is very large so I will likely only access the cabinet from the inside.
My goal is to install it with an AC adapter if possible and save the cost of an 110v-to-12v dc inverter.
So, I am asking for your help:
Is there a fan which you recommend that is 12cm Thermally controlled, low-speed, quiet around 800rpm that includes the AC-to-DC adapter? I am assuming that I won't need to buy a 110v-to-12v DC inverter if it comes with the adapter?
Unfortunately, while the article was great, it didn't list where to buy the parts.
Thanks in advance
Anthony
Thanks in advance
Anthony
