I just installed a cat5 cable to connect two computers.
The W2K machine using ipconfig /all reports the following:
Please the "REMOVED BY BUPKUS". I thought better than including unnecessarily risky info.
Windows 2000 IP Configuration
Host Name . . . . . . . . . . . . : REMOVED BY BUPKUS
Primary DNS Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : REMOVED BY BUPKUS
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Cable Disconnected
Description . . . . . . . . . . . : VIA PCI 10/100Mb Fast Ethernet Adapter
Physical Address. . . . . . . . . : REMOVED BY BUPKUS
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : mts.pre.commspeed.net
Description . . . . . . . . . . . : D-Link DFE-530TX+ PCI Adapter
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : REMOVED BY BUPKUS
Subnet Mask . . . . . . . . . . . : REMOVED BY BUPKUS
Default Gateway . . . . . . . . . : REMOVED BY BUPKUS
DHCP Server . . . . . . . . . . . : REMOVED BY BUPKUS
DNS Servers . . . . . . . . . . . : REMOVED BY BUPKUS
............................................ REMOVED BY BUPKUS
Lease Obtained. . . . . . . . . . : Tuesday, April 23, 2002 3:47:51 PM
Lease Expires . . . . . . . . . . : Wednesday, April 24, 2002 3:47:51 AM
Does this mean my cable is discontinuous? How can I test for this warning?
Oh, I forgot. The connection uses 2 cables. One has an RJ45 connector at one end and a Leviton QuickPort on the other.
I made a crossover cable to connect the 2nd pc to the QuickPort.
Leviton-QuickPort
Leviton-QuickPort
