Need help installing Starcraft
yellowperil
4,598
This is installing on a laptop running Windows XP Home. The disc stops when it is installing a 'Lost Civilization' map file and the installation freezes. I thought maybe it was the disc so I tried running a copy but same problem. Is there a known fix or did I just get a bad disc? Thx
Glitchny
5,679
i have never had this problem and i ahve installed that game so many times i cant really count, it must be a bad disk, is it scratched etc?
great game though
Sid59
11,879
if you are using nero..
1. make a NRG image of the CD
2. use something like Daemon Tools or Nero's Image Mounter and mount the image
3. try and install from that.
yellowperil
4,598
Thx guys. I think it was a problem with the CD drive on my laptop. I installed it on the desktop and then copied the SC folder onto my laptop and it works
