Hello all,
I need some serious help with my computer. I've been trying to install a Pioneer DVD-105S (16x, slot) and a Maxtor 80 gig Ultra100 drive for 2 days without any success. So perhaps you guys can point me out to the right direction.
Here's some info you might need to know:
- Azza motherboard
- Award Modular BIOS v.4.51PG
- Award Plug and Play Extension v.1.0A
- Pentium III 450
- 256 MB PC100 SDRAM
- C: (Maxtor 5400, 13 gig) as Primary Master
- D: (Maxtor 5400, 20 gig) as Primary Slave
- E: (Maxtor 5400, 40 gig) connected to Promise ULTRA66 IDE Controller Card
- F: (HP 8200i) as Secondary Master
- G: (44x CDROM) as Secondary Slave
- 250 watt Power Supply
- Windows 98
PIONEER DVD-105S PROBLEM (Assuming I got the jumper setting correct and it's connected to the power supply).
1. I unpluged my CDROM drive (Secondary Slave) and connected the DVD-Rom (set as a Slave), then I re-booted. DOS detected the new DVD-Rom, but after the DOS shows the Windows Start-Up logo, my computer stop responding/frozen.
2. I've tried to switch the master/slave jumpers between my HP CDRW and DVD-Rom, but still couldn't get my computer to load Windows.
3. Tried connecting the DVD-Rom to the Promise ULTRA66 Controller, but suddenly the controller told me that the BIOS for the controller wasn't installed. It could load Windows but both devices connected to the controller (E: and the DVD-Rom) couldn't be detected. This didn't happen when the DVD-Rom wasn't connected to the controller card.
4. Tried to connect the DVD-Rom as a Primary Slave and my C: as a Primary Master. Still couldn't get the computer to go all the way to load windows.
I know for sure that I've set the Jumper (Master/Slave) correctly.
5. Any thought why my computer won't load windows everytime the DVD-Rom's connected?
MAXTOR 5400 80GB ULTRA100 PROBLEM (using the 80-Wire UDMA Interface Cable that came with the retail box)
1. Tried connected this HD as a Secondary Slave, DOS couldn't detect it[/b].
2. Tried connected as a Secondary Master, DOS couldn't detect it.
3. Tried connected as a Slave along with my E: drive to the ULTRA66 Controller Card, it couldn't detect both HD and DOS got frozen.
4. Tried connected as a Master on the 2nd IDE port on the Controller Card, it still couldn't detect both HD and DOS got frozen again.
4. Tried connected as a Primary Slave, DOS couldn't detect it.
5. Tried connected as a Primary Master, DOS couldn't detect it.
6. Finally I used the diskette from Maxtor that came with the HD, hoping that it would help me with the installation. Nope, the diskette itself said there's an error with the new drive.
7. So basically, my computer won't detect this new hard drive.
8. I know for sure the jumper settings were right, and the hard drive is not fried.
I found out that Promise Ultra66 IDE controller can only detect ATA drives, not ATAPI like DVDrom.
Right now I have 2 expensive devices worth $400 just sitting around. Everytime I saw them, I "cry" thinking about the $400 doing nothing... 😛
TIA for any advise.
-mcmlxxv- 😛
- Azza motherboard
- Pentium III 450
- Windows 98
TIA for any advise.
-mcmlxxv- 😛
