Need help installing new hard drive
glp1del
I want to swap out the 4 gig hard drive that is in my brother's system and replace it with an 8.4 gig hard drive. Is there a way to simply copy the current drive onto the new drive or do I need to re-install everything. I was thinking about using dos commands such as xcopy or something.
TIA
Glp1del
bacillus
14,517
<< I was thinking about using dos commands such as xcopy or something. >>
for W95, W98, and WindowsMe - You can use the XCOPY32 program.
On your desktop, start, programs, assessories, go to the MSDOS prompt.
Change the directory to: C:\Windows\Command
Next, type this command:
XCOPY32 C:\*.* D:\ /c /e /h /k
This assumes the new drive letter is D.
The command line switches tell Xcopy32 to copy everything, including all subdirectories, hidden files, and system files, and to preserve the long file names and file attributes.
