Hi all,
for those of you who know how to setup Ikonboard v2.19, I need your help.
Windows 2000 Professional
Xitami v2.5b526
Active Perl Build 6
So yeah, I finally got the install.cgi file running after finally figuring out that I needed to download Perl, however after Step 3 in the installation process, or whenever I try to access ikonboard.cgi, it gives me the following error:
Could not find these files: If you are running NT you may need to enter the full path in each require statement in each script
Ok, so naturally I crack open the CGI file, and take a peep at the file paths, and rename them directly to where they are: ex. c:\server\www\cgi-bin\ikonboard\blah.cgi
I also tried using the the regular slash, and that won't work either. It all gives me the same error. Help!
Dong
Xitami v2.5b526
Active Perl Build 6
Dong
