Need help installing HS/F!
FlyingHamster
602
My SK7 w/ a Smart Fan II just came in today, and after opening everything up, I have come to the conclusion that I have no idea as to how to put all this stuff together lol. My Volcano 7+ was quite different...
Is there a guide that shows how to put the SF II together, where to connect all its wires to on the motherboard, and how to connect it to the SK7? Those are the things I need help with.
If any of you could help, I would greatly appreciate it. Thanks in advance..
*how do I post pics? I have several pics of the SK7 w/ SF II that will help u guys understand what Im saying, but I cant figure out how to show a picture lol.
blade
1957 - 2008<br>Elite Moderator Emeritus<br>Troll H
See here for the fan instructions. That's for a V9, but it uses that same fan so it's the same idea. As for attaching it to the SK-7, you use the included clips, they include several sets so try them and you'll find which set fits it best. ;)
Can't post pics here, you can only link to them as I did.
Here's a pic with the clips attached to the sk7
Batman5177
216
look at this picture.
be sure to take your time taking off and putting on the heatsink.
the only wire you have to plug into your motherboard is fan's power wire.
good luck!
