Hello all,
I need a little help getting D2OL running on my new Celery 2.6 and Mandrake 10.0.
The D2OL installer with the Java Runtime included craps out when it tries to install Java. So I've installed Java by itself in another directory and am trying to use the D2OL installer without Java. The problem is that it doesn't know where Java is, and I have no clue how to tell it. Here's what happens after I run the installer:
Preparing to install...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
No Java virtual machine could be found from your PATH
environment variable. You must install a VM prior to
running this program.
Java is installed to /home/swan/j2re1.4.2_04.
Could someone please tell me what I need to type in the command line to let the installer know where Java is?
Thanks,
Swan
Thanks,
Swan
