Need help installing car audio
cchen
6,062
Ok, I'm installing a JVC kd s570 in my 1990 toyota camry and I'm stuck. I removed the factory radio already and I'm looking at the camry's harness. It has two pieces that don't fit into the slot on my jvc. What am I supposed to do? Do I need to buy a wiring harness (i think that's what it's called)? How does that work?
ThisIsMatt
Banned
Aug 4, 2000
11,820
Your JVC should have come with a plug that goes into the head unit with bar wires on the other end. If you don't get a wiring harness, you'll just have to follow the diagram that came with the JVC and cut the wires in the car off the plugs and hook them up manually (solder, wire nuts, twist & electrical tape, whatever).
cchen
6,062
What does the wiring harness do? Does it connect the car connector directly to the jvc?
ThisIsMatt
Banned
Aug 4, 2000
11,820
<< What does the wiring harness do? Does it connect the car connector directly to the jvc? >>
Yes. There may be a few loose wires (say, for automatic antenna or something else that may have been an option on your car).
