Need Help installing a Digi Xem board in a W2k Pro machine
OutHouse
36,410
616
ok this is really starting to piss me off. When i install the card on a brand new install of W2K Pro everything looks normal. The OS detects the card and and the right driver is loaded. I then load the right module (16 port) and com3-19 are assigned.
I look in device Manager and the device is loaded and in the device status window it say device is working normally but i need to reboot to make the changes take effect.
After the reboot is when it breaks. When i check device manager its showing in Device status "error code 10 device can not start"
I have uninstalled it, reinstalled it, disabled it, renabled it. loaded new drivers from Digi and i still can not get this to work.
How can i fix this?????
