Hello all,
I just bought a 3Com AirConnect 802.11b adapter and am trying to install it on a new Dell Inspiron 1100 laptop. The laptop has XP home on it. The problem is that XP is messing up the hardware installation and I can't stop it. When I put the card in it does the auto detect and then proceeds to auto install stuff, all without any input from me. The problem is that it must install that wrong driver, because it causes the whole system to freeze. The only way to unfreeze it is to remove the card. Then when you put the card in again it just freezes immediately. I'm used the system restore to go back and try again, but it screws up every time. I can't figure out a way to stop the auto hardware installation. Also, the device doesn't show up in the hardware manager, so I can't change it there after the first attempt.
So, how do I make it so it doesn't start it's stupid auto install the first moment I plug in the card? Any other ideas? And yes, I've waited for about 10 minutes once. It also freezes in the boot if you put the card in and then power up the machine. Once you take the card out, it continues to boot normally
Thanks for any help,
Swan
Swan
